Caddy v1.0.4
sudo caddy run
https://0x29a.fi for the website and for the icecast2 http://0x29a.fi:8000/0x29a
Ubuntu 16.04.6 LTS
0x29a.fi {
root /var/www/web
gzip
fastcgi / /var/run/php/php7.0-fpm.sock php
I have problem to serve icecast2 url to https. My normal site works fine https://0x29a.fi, but icecast2 not working with audio elements because:
With Chrome 80, released in January, Chrome attempts to [automatically upgrade HTTP media requests to HTTPS]. If the server doesn’t supply HTTPS media, the request will fail.
I need to serve http:// 0x29a .fi :8000/0x29a via https
I’m trying to use this example: Icecast HTTPS/SSL with Let's Encrypt: Setup Guide but not good results.
http: TLS handshake error from ip-address:674: tls: first record does not look like a TLS handshake
[INFO] 81.4.103.120 - No such site at :80 (Remote: ip-address, Referer: http://ip-address:80)
letsencrypt cert creation: Problem binding to port 80: Could not bind to IPv4 or IPv6.
