1. Output of caddy version
2.5.2
Windows 10 Enterprise
caddy adapt --config caddy\Caddyfile.client
0.0.0.0:8446 {
log stdout
errors stderr
tls self_signed
proxy / http://localhost:3100 {
websocket
keepalive 10
header_downstream Content-Security-Policy "default-src 'self'; style-src 'self' 'unsafe-inline'; object-src 'none'; img-src 'self' data:;"
proxy /devel-login-kips https://maasikas.dev.icefire {
keepalive 10
proxy /kks-api http://localhost:9021 {
keepalive 10
proxy /filetransfer http://klaabu.mta:12220 {
rewrite {
if {path} has configuration
if {path} not_has kks-api
to /config.client.dev.json
I need to develop new functionality for a project I have never done anything for. For local development the Readme told that I need to use Caddy for HTTPS proxying. I have installed caddy, but when I try to load the config then it gives me an error (see below). I can only assume that back in 2018 the syntax for caddyfile was different. Can someone please verify if that is the case and if so then what version of caddy should I install and what would be the simplest method of installing it?
As a sidenote then my project’s readme had the following steps for running Caddy (it did not work). So I adjusted the syntax for loading config as written above. The readme had the following steps:
Add HTTPS proxy using Caddy server and start local webpack-dev-server
($PROJECT_HOME
is corresponding project home directory)
- Download Caddy
- Unpack to
$CADDY_HOME
(C:/caddy
or other applicable directory) - Run from terminal window / cmd:
$CADDY_HOME\caddy --conf caddy\Caddyfile.client.dev
adapt: parsing caddyfile tokens for 'log': caddy\Caddyfile.client:2 - Error during parsing: Wrong argument count or unexpected line ending after 'stdout'
As written above then I tried loading the config with syntax that works, but it doesn’t load the file…
