Decided not to start the post with the template and please don’t be upset - I assure you the request has nothing to do with the config I am using Caddy as a reverse proxy for a lot of custom traffic. I have a working Caddyfile configured to my needs, but I’m just wondering if there exists a shorthand with Caddyfile for not applying the tls
directive to specific sites?
I am using port 8080 for HTTP and 8443 for HTTPS, due to ports 80/443 being used for something else. So I apply for Let’sEncrypt certs manually and point to them them inside Caddyfile.
My Caddyfile is something like this
http_port 8080
https_port 8443
http://mysite.com {
@exclude { not path /app1 /app2 /app3 ... /app100 }
reverse_proxy /app1 172.0.0.1:80
reverse_proxy /app2 172.0.0.2:80
reverse_proxy /app3 172.0.0.3:80
reverse_proxy /app100 172.0.0.100:80
root @exclude /var/www
https://mysite.com {
tls /path/ssl.crt /path/ssl.key
@exclude { not path /app1 /app2 /app3 ... /p100 }
As you can see, the HTTP and HTTPS blocks are basically identical apart from the tls
directive. By separating them into different blocks, extra effort is needed to maintain them and to avoid mistakes, that is at least until I’ve figured out the JSON config method.
Is there way I can put both the http and https servers in the same block, and apply an exclude rule to the tls
directive so that the tls setting is ignored by the HTTP service, similar to the behavior of Caddy1?
Many thanks.
service caddy start
systemd
http_port 8080
https_port 8443
http://cyberpunk.buzz {
@exclude { not path /app1 /app2 /app3 }
https://cyberpunk.buzz {
tls /etc/ssl/caddy.pem /etc/ssl/caddy.key
Have to remove some of the paths to increase clarity.
Need to repeat 99% of the configurations inside the HTTP and HTTPS block, as Caddy2 will throw startup error once a TLS directive exists in a configuration with HTTP.
Dec 22 22:26:27 Caddy caddy[2389]: {"level":"info","ts":1608647187.9637349,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
Dec 22 22:26:27 Caddy caddy[2389]: reload: adapting config using caddyfile: server listening on [:8080] is HTTP, but attempts to configure TLS connection policies
Dec 22 22:26:27 Caddy systemd[1]: caddy.service: Control process exited, code=exited, status=1/FAILURE
Separate config blocks for HTTP and HTTPS
