How do I configure the proxy to connect to the backend using the same protocol as the incoming http request? I.e. if the internet user connects with http, connect to the backend using https. And likewise for http
If you separate the incoming requests like so it should work:
http://example.com {
proxy / http://upstream.example.com {
https://example.com {
proxy / https://upstream.example.com {
I believe this also has the effect of removing the automatic redirection from http to https.
