v2.0
sudo caddy --config caddy.json
ubuntu 18.04
sudo caddy run --config caddy.json
"logging": {
"logs": {
"default": {
"exclude": [
"http.log.access.log0"
"log0": {
"writer": {
"filename": "access_dom1.log",
"output": "file"
"encoder": {
"field": "common_log",
"format": "single_field"
"include": [
"apps": {
"http": {
"servers": {
"srv0": {
"listen": [
":443"
"idle_timeout": "200ms",
"routes": [
"match": [
"host": [
"example.net"
"handle": [
"handler": "subroute",
"routes": [
"handle": [
"handler": "vars",
"root": "/var/www/bench/bench/public"
"handle": [
"handler": "static_response",
"headers": {
"Location": [
"{http.request.uri.path}/"
"status_code": 308
"match": [
"file": {
"try_files": [
"{http.request.uri.path}/index.php"
"not": [
"path": [
"group": "group0",
"handle": [
"handler": "rewrite",
"uri": "{http.matchers.file.relative}"
"match": [
"file": {
"try_files": [
"{http.request.uri.path}",
"{http.request.uri.path}/index.php",
"index.php"
"handle": [
"encodings": {
"gzip": {},
"zstd": {}
"handler": "encode"
"handle": [
"handler": "reverse_proxy",
"transport": {
"protocol": "fastcgi",
"split_path": [
".php"
"read_timeout": "300ms",
"write_timeout": "300ms"
"upstreams": [
"dial": "unix//run/php/php7.3-fpm.sock"
"match": [
"path": [
"*.php"
"terminal": true
"logs": {
"logger_names": {
"example.net": "log0"
I’ve gotten everything set up to mostly resemble my nginx conf. I’m trying to do some load testing between nginx and caddy. I’m using locust for testing, nginx is able to get to 135 RPS (requests per second) with no issue. Caddy can get to about 55 RPS before throwing read unix @->/run/php/php7.3-fpm.sock: i/o timeout
I’m assuming this is because of the timeout I set.
before i set the time out i was getting the error read unix @->/run/php/php7.3-fpm.sock: too many open files
When i do lsof | grep -e caddy
i get hundreds (up to the limit i set for php) of
caddy 17476 17724 root 1011u IPv6 13599486 0t0 TCP xxx.xxx.xxx.xx:https->xx-xxx-xxx-xxx-static.hfc.comcastbusiness.net:61893 (ESTABLISHED)
From what i’ve seen other users post caddy vs nginx shows they are fairly similar. If i can get this figured out this will be my final question
2020/05/20 16:26:38.902 ERROR http.log.error.log0 dialing backend: dial unix /run/php/php7.3-fpm.sock: socket: too many open files {"request": {"method": "GET", "uri": "/", "proto": "HTTP/1.1", "remote_addr": "xxx.x.xxx.xx:55557", "host": "example.net", "headers": {"User-Agent": ["python-requests/2.23.0"], "Accept-Encoding": ["gzip, deflate"], "Accept": ["*/*"], "Connection": ["keep-alive"], "Cookie": ["XSRF-TOKEN=eyJpdiI6InVLUkFWV1VYZ1NLQW5oVHhEZXdCQ1E9PSIsInZhbHVlIjoianp1NzQzT21ZODRYZjVnbEkwalBRTVNQKzhrZTNDVEdKL3FPYXB5bDAvRXZrSDloSGk5dWNQTEFxS295QVFibSIsIm1hYyI6ImY4ODliYTIyNjg3MTRlODA5MmZhOWE2MjVhNThkYWUyYTFkNjM3ODhlNTVjMDFlNmZhOGRjZjZmYTYzMmRjZTMifQ%3D%3D; laravel_session=eyJpdiI6IjI4UzltdzN1ZVRPcEZHZnpUTUhYN1E9PSIsInZhbHVlIjoibDVJU2xpQlJzTXlBaEVqRmNXM1VtNWlOcUNobFc3Yk9nVUN6bHYzMEErYkZ0b3dzbDFQU2d4K3g1eHpJdjdSMCIsIm1hYyI6IjhiNTRkYThmYzZkYWM0ODExYzQ5OWNjMDgzZWYzMWZjY2VjYTlmODRkZjlkOWViMGY0N2IzNDVjYjgwNjY5N2YifQ%3D%3D"]}, "tls": {"resumed": false, "version": 772, "ciphersuite": 4865, "proto": "", "proto_mutual": true, "server_name": "example.net"}}, "duration": 0.001816113, "status": 502, "err_id": "69thix4hx", "err_trace": "reverseproxy.(*Handler).ServeHTTP (reverseproxy.go:380)"}
http.log.error.log0 read unix @->/run/php/php7.3-fpm.sock: i/o timeout {"request": {"method": "GET", "uri": "//", "proto": "HTTP/1.1", "remote_addr": "xx.xxx.xxx.xxx:52682", "host": "example.net", "headers": {"User-Agent": ["python-requests/2.23.0"], "Accept-Encoding": ["gzip, deflate"], "Accept": ["*/*"], "Connection": ["keep-alive"]}, "tls": {"resumed": false, "version": 772, "ciphersuite": 4865, "proto": "", "proto_mutual": true, "server_name": "example.net"}}, "duration": 0.300784001, "status": 502, "err_id": "r5sbn4tqe", "err_trace": "reverseproxy.(*Handler).ServeHTTP (reverseproxy.go:380)"}
