Certmagic should work with Zerossl, and it even has a constant for the ACME API.
Forgive me if this should be obvious,
but how does one pass your ZeroSSL ‘access key’ to Zerossl when using Certmagic?
Thanks
CertMagic itself is not a ZeroSSL API client. You can use your ZeroSSL EAB credentials with CertMagic, though. Or, Caddy has a ZeroSSL API client built-in if you are using that, which accepts the API key.
