davidak
(davidak)
July 16, 2016, 11:19pm
1
Caddyfile :
redir /blog/wp-content/uploads/2010/12/Bildschirmfoto-2010-12-14-um-19.47.29-1024x640.png /images/celtx_auf_osx_wortspiele_polysemia.thumbnail.png
Error:
caddy[8444]: 2016/07/17 00:57:32 Caddyfile:23 - Parse error: Invalid redirect code '/images/celtx_auf_osx_wortspiele_polysemia.thumbnail.png'
when i understand the example right that should work.
what am i doing wrong?
davidak
(davidak)
July 17, 2016, 12:08am
2
I fixed it by only using the redir directive once but with multiple urls.
matt
(Matt Holt)
July 17, 2016, 6:25am
3
You’re missing the redirect code; the example uses 307.
davidak
(davidak)
July 17, 2016, 2:28pm
4
Default is 301 Moved Permanently.
and that is what i want. in what case do i have to set it explicitly?
matt
(Matt Holt)
July 17, 2016, 6:06pm
5
Oh, umm maybe that’s not true for the table form. I’ll double check and make the fix.
matt
(Matt Holt)
July 19, 2016, 12:32am
6
Okay, so actually this isn’t a bug; using this format: redir from to code
, all 3 values are required. This is still correct in the docs because the code
parameter doesn’t have those optional [ ]
brackets around it. The default code is still 301, but only when the syntax allows it to be omitted.
I’ll try to clear that up in the docs.
system
(system)
Closed
October 17, 2016, 12:32am
7
