22749
(Tobias)
December 22, 2016, 4:06pm
#1
Using:
https://caddyserver.com/download/build?os=linux&arch=arm&arm=6&features=
and:
domain.tld:2015 {
root /home/pi/tt-rss
tls /home/pi/concat.pem /home/pi/ssl.key
fastcgi / /var/run/php5-fpm.sock php
domain.tld:3000 {
root /home/pi/podcast
tls off
browse
gzip
everything works with 0.9.3! With 0.9.4 only the :3000 works, requests to the :2015 give error 500 and:
[PANIC] runtime error: invalid memory address or nil pointer dereference
matt
(Matt Holt)
December 22, 2016, 5:57pm
#2
What does the log say? Run with -log stderr
for example to see the full output. Also turn on the errors
directive for an error log.
22749
(Tobias)
December 22, 2016, 6:18pm
#3
With -log filename
I get the PANIC line above, with -log stderr
I also get a line number:
[PANIC /] /usr/local/go/src/sync/atomic/asm_linux_arm.s:109 - runtime error: invalid memory address or nil pointer dereference
(why the difference?)
The errors
directive doesn’t change anything.
matt
(Matt Holt)
December 22, 2016, 7:35pm
#4
Hmm, that’s a file in the Go standard library. Maybe we have a nil mutex somewhere?
The errors directive should write a more detailed error log. Is there nothing in the error log?
You say the error has to do with fastcgi. If you take that line out of your Caddyfile, does the error still occur?
zwieratko
(Radovan Snirc)
December 22, 2016, 7:43pm
#5
the same for raspberry pi, downloaded via browser from url: https://caddyserver.com/download/build?os=linux&arch=arm&arm=6&features=
22/Dec/2016:19:51:21 +0100 [PANIC /] /usr/local/go/src/sync/atomic/asm_linux_arm.s:109 - runtime error: invalid memory address or nil pointer dereference
and the same situation on the hosted debian i686
downloaded via wget https://github.com/mholt/caddy/releases/download/v0.9.4/caddy_linux_386.tar.gz
22/Dec/2016:18:32:08 +0100 [PANIC /] /usr/local/go/src/sync/atomic/asm_386.s:112 - runtime error: invalid memory address or nil pointer dereference
22/Dec/2016:18:32:14 +0100 [PANIC /dist/purify.min.js.map] /usr/local/go/src/sync/atomic/asm_386.s:112 - runtime error: invalid memory address or nil pointer dereference
22/Dec/2016:18:32:20 +0100 [PANIC /] /usr/local/go/src/sync/atomic/asm_386.s:112 - runtime error: invalid memory address or nil pointer dereference
22/Dec/2016:18:32:20 +0100 [PANIC /dist/purify.min.js.map] /usr/local/go/src/sync/atomic/asm_386.s:112 - runtime error: invalid memory address or nil pointer dereference
matt
(Matt Holt)
December 22, 2016, 8:12pm
#6
That’s 64-bit linux, no? You downloaded the 32-bit version.
Are you sure you got the ARM version right for your Pi?
matt
(Matt Holt)
#7
What kind of machine are you running this on?
22749
(Tobias)
December 22, 2016, 8:28pm
#8
There really is nothing in the error log.
Without FastCGI the panic doesn’t occur, just a 404.
ARMv6 is the correct binary for a Raspberry Pi 1. I used the exact same URL in September to get a build that doesn’t panic.
zwieratko
(Radovan Snirc)
December 22, 2016, 8:31pm
#9
no, i686 is 32bit, I’m sure, caddy 0.9.4 running ok but all request to fastcgi get error 500
yes, I’m sure raspberrypi1 is arm6, caddy 0.9.4 running ok but the same problem with fastcgi
and caddy 0.9.4 arm7 build running on raspberrypi2 is ok, it’s reverse proxy, but request which is not send to backend but send to fastcgi get the same error 500
matt
(Matt Holt)
December 22, 2016, 8:37pm
#10
Can you file a bug at https://github.com/mholt/caddy/issues and include the information you gave here (and link to this thread)? If both of you could contribute, that would be good. Seems like the same or at least a similar issue for you both.
22749
(Tobias)
December 22, 2016, 9:43pm
#11
matt
(Matt Holt)
December 22, 2016, 9:47pm
#12
Thanks. I have a strong suspicion as to the fix, will take the discussion to that issue now!
Edit: Fixed! Thank you.
devil1591
(Guillaume)
December 26, 2016, 9:21pm
#13
Hi Matt,
you should push a new version quickly as this one is unusable in production with PHP…don’t you think?
matt
(Matt Holt)
December 26, 2016, 10:32pm
#14
Yes. I would if doing deploys didn’t take me half a day.
superl2
(Joshua Leivenzon)
January 10, 2017, 7:08am
#15
I’m having the same issue. How can I download Caddy 0.9.3 with plugins?
EDIT: Doesn’t matter, using caddy 0.9.3 from a backup. But please push the fix soon…
system
(system)
closed
April 10, 2017, 7:09am
#16
