Thatâs more of a âhow do I use my computerâ kind of question, honestly. There are countless guides on the internet that can explain that for you.
Typically youâd move the binary to /usr/local/bin which is one of the various directories that are in your PATH by default:
Thank you for your help. I understand PATH now. I had used it quite a bit in Windows, but am a complete newb in linux. So I used curl to download https://github.com/caddyserver/xcaddy/releases/download/v0.1.6/xcaddy_0.1.6_linux_amd64.tar.gz and moved it to /usr/local/bin. I tried the xcaddy command and it didnât work. Then I opened up ~/.profile and added this line to the end export PATH=$PATH:/usr/local/bin. I tried the xcaddy command and it still didnât work. I also rebooted the linux server after each step.
What am I missing?
