Own Caddy module not working
Hi, I tried to implement a Caddy module which encodes incoming request URLs using Base64 encoding and redirects clients to a specified target URL with the encoded URL appended.
My source code can be found here:
I configured it in my Caddyfile like described in 4d.
Since my console print in init() can be found in the output, it seems to be registered, but unfortunately the rest is not working.
Thanks in advance!
Registering Base64Redirect module
{"level":"info","ts":1732030412.894132,"msg":"using config from file","file":"/etc/caddy/Caddyfile"}
Error: adapting config using caddyfile: parsing caddyfile tokens for 'route': unrecognized directive: base64_redirect - are you sure your Caddyfile structure (nesting and braces) is correct?, at /etc/caddy/Caddyfile:10
Caddy v2.8.4
I build Caddy with
GOOS=linux GOARCH=amd64 xcaddy build --with github.com/jomo02/base64-redirect
and run it via Docker (Compose)
Ubuntu 20.04.6 LTS
Docker 27.1.0
Docker Compose version v2.29.0
docker compose up -d
c. Compose file:
    image: caddy:2
      - 443:443
      - 443:443/udp
      - ./caddy:/usr/bin/caddy
      - ./caddy-config:/config
      - ./caddy-data:/data
http://domain1.com {
    route {
        base64_redirect {
            target https://domain2.com/viewer/
You didn’t add Caddyfile support for your module. See Caddyfile Support — Caddy Documentation
