1. Output of caddy version
v2.6.2
systemctl start caddy
Ubuntu 22.04
version: "3.7"services:
image: lucaslorentz/caddy-docker-proxy:ci-alpine
- 443:443
- CADDY_INGRESS_NETWORKS=caddy
- caddy
- caddy_data:/data
external: true
caddy_data: {}
{"level":"warn","ts":1668465310.3188334,"logger":"http.acme_client","msg":"HTTP request failed; retrying","url":"https://acme-v02.api.letsencrypt.org/directory","error":"performing request: Get \"https://acme-v02.api.letsencrypt.org/directory\": dial tcp: lookup acme-v02.api.letsencrypt.org on 127.0.0.11:53: read udp 127.0.0.1:58775->127.0.0.11:53: i/o timeout"}
{"level":"error","ts":1668465310.3189132,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"portainer.darwinlegend.com","issuer":"acme-v02.api.letsencrypt.org-directory","error":"registering account [] with server: provisioning client: performing request: Get \"https://acme-v02.api.letsencrypt.org/directory\": dial tcp: lookup acme-v02.api.letsencrypt.org on 127.0.0.11:53: read udp 127.0.0.1:58775->127.0.0.11:53: i/o timeout"}
{"level":"warn","ts":1668465310.3192294,"logger":"http","msg":"missing email address for ZeroSSL; it is strongly recommended to set one for next time"}
{"level":"error","ts":1668465311.3203595,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"portainer.darwinlegend.com","issuer":"acme.zerossl.com-v2-DV90","error":"account pre-registration callback: performing EAB credentials request: Post \"https://api.zerossl.com/acme/eab-credentials-email\": dial tcp: lookup api.zerossl.com on 127.0.0.11:53: read udp 127.0.0.1:42648->127.0.0.11:53: i/o timeout"}
{"level":"error","ts":1668465311.3204167,"logger":"tls.obtain","msg":"will retry","error":"[portainer.darwinlegend.com] Obtain: account pre-registration callback: performing EAB credentials request: Post \"https://api.zerossl.com/acme/eab-credentials-email\": dial tcp: lookup api.zerossl.com on 127.0.0.11:53: read udp 127.0.0.1:42648->127.0.0.11:53: i/o timeout","attempt":1,"retrying_in":60,"elapsed":4.506157007,"max_duration":2592000}
I follow the example from this link :
but I have an error
