I’m trying to get OpenBSD’s bgplg (BGP looking glass) working with Caddy.
The original implementation assumed nginx and works well with this config:
ext_addr="0.0.0.0"
server "lg.example.net" {
listen on $ext_addr port 80
location "/cgi-bin/*" {
fastcgi
root ""
When I try to get this working in Caddy I see the page load, but the drop down menu (using the binary bgplgsh) does not work. nginx would assume the existence of resolv.conf and a few related binaries under:
var/www/cgi-bin/bgplg
/var/www/cgi-bin/bgplg
/var/www/etc
It would also use a local socket to communicate with the bgp daemon:
socket "/var/www/run/bgpd.rsock" restricted
See:
https://man.openbsd.org/bgplg.8
http://www.ogris.de/howtos/openbsd-looking-glass.html
Any help on getting this to work with Caddy is appreciated, it’d help me turn off running nginx on port 81.
