I’m using on-demand TLS and https-only which work really great.
Just two smaller “issues” that maybe could improve my setup.
The TLS-ask configuration basically tells Caddy to ask first and then try to retrieve a certificate. If a request is made to non-https there will be a redirect response to https.
This is fine if the ask-endpoint returns 200, but what if it doesn’t? The user will be greeted with an SSL_ERROR_INTERNAL_ERROR_ALERT
in their browser.
Is there a way to extend asking to before the redirect to HTTP is done? Basically a “domain-on-demand”? For my application this doesn’t make a big difference, but it would improve UX quite a bit if Caddy responded with a 404 before answering an HTTP request with an invalid certificate.
Furthermore, if the backend response was “do not request a certificate”, Caddy will ask again on the next request. Can this response be cached? I’m seeing quite a few scripted attempts to hack the server, some with completely bogus domain names. This would prevent the (very fast) backend from ever having to check twice. (If there was a cacheable way to check for eligible domains this wouldn’t be an issue though.)
Curl example on Caddy 2.8.4:
curl -kiL we-dont-serve-this.domain
HTTP/1.1 308 Permanent Redirect
Connection: close
Server: Caddy
Date: Fri, 11 Oct 2024 08:55:41 GMT
Content-Length: 0
curl: (35) OpenSSL/3.2.2: error:0A000438:SSL routines::tlsv1 alert internal error
