Whatever is the latest
Though Docker via unRAID
unRAID Docker
na
Paste command here.
none
plex.digitalwashu.net
reverse_proxy 192.168.1.10:32400
Not resolving
{"level":"info","ts":1646698287.085654,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
{"level":"warn","ts":1646698287.0865178,"msg":"input is not formatted with 'caddy fmt'","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":4}
{"level":"info","ts":1646698287.087166,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["localhost:2019","[::1]:2019","127.0.0.1:2019"]}
{"level":"info","ts":1646698287.0872614,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
{"level":"info","ts":1646698287.0872767,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
{"level":"info","ts":1646698287.0874045,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0003c6930"}
{"level":"info","ts":1646698287.0875642,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["plex.digitalwashu.net"]}
{"level":"info","ts":1646698287.0875852,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/data/caddy"}
{"level":"info","ts":1646698287.0996137,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
{"level":"info","ts":1646698287.0996256,"msg":"serving initial configuration"}
{"level":"info","ts":1646698287.1982331,"logger":"tls","msg":"finished cleaning storage units"}
This is likely not Caddy-specific. I can’t seem to get reverse proxy to work with ANY rev proxy tool. MY firewall is pfSense, and in it, I have 80 and 443 open. I have NAT set to forward 80–>1880 and 443–>18443.
I’m completely baffled as to why this isn’t working. I will say however Caddy is WILDLY more simple than traefik/nginx/haproxy. Holy smoke.
