Not able to get response on https 127.0.0.1
Hi, I’m trying to use https locally. When I access https://localhost, I get the expected html response, but when I try https://127.0.0.1, the browser gives error “This site can’t provide a secure connection”
3. Caddy version: v2.8.4
a. System environment: docker on linux amd64
    image: caddy
      - 443:443
localhost, 127.0.0.1 {
        #tls internal Default behavior
        header Content-Type "text/html"
        respond "<h1> Welcome!</h1>" 200
When you run Caddy inside a container, 127.0.0.1 means “this same container”. Containers have their own network, like if it was another machine on your LAN. Requests will have your Docker gateway IP on them, not 127.0.0.1, so the Host header doesn’t match.
