PS
I am not asking for help. I had this problem and figured out why it was happening and how to fix it. I believe that someone else may have the same problem, so I am creating this to help others.
I also would like to let you know that I am no expert, just a beginner trying to help others beginners. (My english isn’t great as well).
The problem I had
I wasn’t being able to connect php and caddy via socket. Even after set up both caddy and php-fpm to work on socket, they wouldn’t work (but it would work if I set on port).
I figured out (after studying about sockets) that they have the same permission system of files. The problem I had was because I was trying to access the sock (on /run/php/php7.4-fpm.sock
) with an user who hadn’t access to it.
Well, now that you understand the why of the problem, there are many ways to fix it. I am going to point one out (it is the I did)
Here is how I manged to fix it:
on file /etc/php/7.4/fpm/pool.d/www.conf
, I set this configurations:
user = www-data ; user of the php-fpm process
group = www-data ; group of the php-fpm process
listen = /run/php/php7.4-fpm.sock ; where the socket will be created
listen.owner = www-data ; the user owner of the socket connection
listen.group = www-data ; the group owner of the socket connection
listen.mode = 0660 ; the permission of the socket connection
on Caddyfile, I set this configurations:
debug # just to know if something is broken
localhost:9090 {
root * /home/benjamin/projects/website_cool_tea/src
The problem is that our caddy
user doesn’t have access in the sock.
To fix this, we could add the caddy
user to the www-data
group by using the command sudo usermod -a -G www-data caddy
. Then restart the php-fpm (sudo systemctl restart php7.4-fpm.service
) and caddy (sudo systemctl restart caddy
or caddy restart
, depending on how you are running caddy).
Also, make sure that your website’s file is accessible to caddy (if it has permission to read and write). If you are uncertain if it has permission, use chmod 777 /path/to/your/website/files -R
, but be aware that it is just for testing, don’t keep 777. You may also need to restart you computer.
This is it folks, I hope it helps someone. Apologizes for not following the template, I judge that it wouldn’t be necessary.
