No redirection to HTTPS site
Certain devices, when accessed with Caddy, redirect to HTTP rather than HTTPS. If I enter the device IP directly into the browser, it works great in HTTPS but not through caddy.
Jul 17 15:34:48 LA-255 caddy[1449]: {"level":"warn","ts":1689588288.9644248,"logger":"tls","msg":"stapling OCSP","error":"no OCSP stapling for [northciscos1.idfy.local]: no OCSP server specified in certificate","identifiers":["northciscos1.idfy.local"]}
Jul 17 15:34:48 LA-255 caddy[1449]: {"level":"debug","ts":1689588288.9644325,"logger":"tls.cache","msg":"added certificate to cache","subjects":["northciscos1.idfy.local"],"expiration":1689630167,"managed":true,"issuer_key":"local","hash":"f60f849fbf5565b7f1ad130d85cc6da5407fdf349715fe1a2319b674fd543351","cache_size":7,"cache_capacity":10000}
Jul 17 15:34:48 LA-255 caddy[1449]: {"level":"debug","ts":1689588288.9644432,"logger":"events","msg":"event","name":"cached_managed_cert","id":"e4621a43-b298-4284-9843-3214df883a61","origin":"tls","data":{"sans":["northciscos1.idfy.local"]}}
Jul 17 15:34:48 LA-255 caddy[1449]: {"level":"debug","ts":1689588288.964459,"logger":"http","msg":"servers shutting down with eternal grace period"}
Jul 17 15:34:48 LA-255 caddy[1449]: {"level":"info","ts":1689588288.9645457,"logger":"tls.cache.maintenance","msg":"stopped background certificate maintenance","cache":"0xc0003f87e0"}
Jul 17 15:34:48 LA-255 caddy[1449]: {"level":"info","ts":1689588288.9647782,"msg":"autosaved config (load with --resume flag)","file":"/var/lib/caddy/.config/caddy/autosave.json"}
Jul 17 15:34:48 LA-255 caddy[1449]: {"level":"info","ts":1689588288.9648135,"logger":"admin.api","msg":"load complete"}
Jul 17 15:34:48 LA-255 caddy[1449]: {"level":"info","ts":1689588288.9658685,"logger":"admin","msg":"stopped previous server","address":"localhost:2019"}
4. Curl command output:
*   Trying 10.10.10.10:443...
* Connected to northciscos1.idfy.local (10.10.10.10) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
*  CApath: /etc/ssl/certs
* TLSv1.2 (IN), TLS header, Certificate Status (22):
* TLSv1.2 (IN), TLS header, Finished (20):
* TLSv1.2 (IN), TLS header, Supplemental data (23):
* TLSv1.2 (OUT), TLS header, Unknown (21):
* TLSv1.3 (OUT), TLS alert, unknown CA (560):
* SSL certificate problem: self-signed certificate
* Closing connection 0
curl: (60) SSL certificate problem: self-signed certificate
how to fix it, please visit the web page mentioned above.
Ubuntu 22.04.2 LTS
b. My complete Caddy config:
northciscos1.idfy.local {
        reverse_proxy 10.10.10.10
        tls internal
northciscos2.idfy.local {
        reverse_proxy 10.10.10.8
        tls internal
firewall.idfy.local {
        reverse_proxy 10.10.10.1:17322
        tls internal
southciscos1.idfy.local {
        reverse_proxy 10.10.20.10
        tls internal
southciscos2.idfy.local {
        reverse_proxy 10.10.20.11
        tls internal
arubawifi.idfy.local {
        reverse_proxy 10.10.30.2
        tls internal
smartoffice.idfy.local {
        reverse_proxy 172.16.3.251:82
        tls internal
I don’t understand. Neither your logs nor your curl command show evidence of a redirect. And you omitted the actual curl command you ran and only shared its output, so I don’t know what you tried.
Are you sure your DNS is correctly pointed to your Caddy server’s IP address?
I’m having trouble with two devices: northciscos1.idfy.local and northciscos2.idfy.local. The issue is that when I try to visit the device using the above domain name, I get a device page but the browser bar says HTTP rather than HTTPS. So I’m not sure if it’s related to Caddy or some other configuration. If you look at the Curl command output, you’ll notice that one message says, curl failed to verify legitimacy of the server.
Okay, and are you sure those domains have their DNS pointing to your Caddy server?
Please accept my apologies for the delay. Thank you; it is now working.
