): 2.4.1
$ docker-compose version
docker-compose version 1.24.0, build 0aa59064
docker-py version: 3.7.2
CPython version: 3.6.8
OpenSSL version: OpenSSL 1.1.0j 20 Nov 2018
$ docker version
Client:
Version: 18.09.5
API version: 1.39
Go version: go1.10.8
Git commit: e8ff056
Built: Thu Apr 11 04:43:57 2019
OS/Arch: linux/amd64
Experimental: false
Server: Docker Engine - Community
Engine:
Version: 18.09.5
API version: 1.39 (minimum version 1.12)
Git commit: e8ff056
Built: Thu Apr 11 04:10:53 2019
Experimental: false
On Ubuntu 18.04
env DOMAIN=adv-shr-elasticsearch2-dev.westeurope.cloudapp.azure.com docker-compose -f docker-compose.yml -f docker-compose.azurevm-highperf-caddy.yml
docker-compose.yml
version: "2"
elasticsearch:
build:
context: elasticsearch/
- elasticsearch-data:/usr/share/elasticsearch/data
- ./elasticsearch/config/elasticsearch.yml:/usr/share/elasticsearch/config/elasticsearch.yml:ro
node.name: elasticsearch
cluster.initial_master_nodes: elasticsearch
ES_CLUSTER_NAME: search-cluster
ES_DATA_DIR: /usr/share/elasticsearch/data
- elk
kibana:
build:
context: kibana/
- kibana-data:/usr/share/kibana/data
- ./kibana/config/:/usr/share/kibana/config:ro
KB_DATA_DIR: /usr/share/kibana/data
KB_ELASTICSEARCH_URL: http://elasticsearch:9200
KB_SERVER_NAME: kibana
- elk
depends_on:
- elasticsearch
elasticsearch-data:
driver: local
kibana-data:
driver: local
elk:
driver: bridge
version: "2"
elasticsearch:
restart: always
ES_JAVA_OPTS: "-Xmx4000m -Xms4000m"
kibana:
restart: always
KB_BASE_PATH: /kibana
image: caddy:2.4.1
restart: always
- caddy-config:/config
- caddy-data:/data
- ./caddy:/etc/caddy
- 443:443
- elk
depends_on:
- elasticsearch
caddy-config:
driver: local
caddy-data:
driver: local
email alexander@skwar.me
{$DOMAIN}:443
encode zstd gzip
level DEBUG
output file /data/access.log {
roll_size 10MB
roll_keep 10
handle_path /elasticsearch* {
basicauth bcrypt Elasticsearch {
import elasticsearch.auth.*
reverse_proxy http://elasticsearch:9200
handle_path /kibana* {
basicauth bcrypt kibana {
import kibana.auth.*
reverse_proxy http://kibana:5601
When I try to connect to the system with https and curl (or any browser, for that matter), I get an error:
curl -v https://adv-shr-elasticsearch2-dev.westeurope.cloudapp.azure.com/
* Trying 52.174.xx.xxx...
* TCP_NODELAY set
* Connected to adv-shr-elasticsearch2-dev.westeurope.cloudapp.azure.com (52.174.xx.xxx) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
CApath: /etc/ssl/certs
* TLSv1.3 (IN), TLS alert, Server hello (2):
* error:14094438:SSL routines:ssl3_read_bytes:tlsv1 alert internal error
* stopped the pause stream!
* Closing connection 0
{"level":"info","ts":1623244031.5708134,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
{"level":"info","ts":1623244031.5738392,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["localhost:2019","[::1]:2019","127.0.0.1:2019"]}
{"level":"info","ts":1623244031.575923,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0000e9650"}
{"level":"info","ts":1623244031.575854,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
{"level":"info","ts":1623244031.5759695,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
{"level":"info","ts":1623244034.971001,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/data/caddy"}
{"level":"info","ts":1623244034.9712322,"logger":"tls","msg":"finished cleaning storage units"}
{"level":"debug","ts":1623244034.9728982,"logger":"http","msg":"starting server loop","address":"[::]:443","http3":false,"tls":true}
{"level":"debug","ts":1623244034.9729648,"logger":"http","msg":"starting server loop","address":"[::]:80","http3":false,"tls":false}
{"level":"info","ts":1623244034.974246,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
{"level":"info","ts":1623244034.9742641,"msg":"serving initial configuration"}
{"level":"debug","ts":1623244040.1820939,"logger":"http.stdlib","msg":"http: TLS handshake error from 193.118.53.202:51252: no certificate available for '172.21.0.4'"}
When I compare the log output of this vm to a vm where Caddy works, I find that in the latter case there’s also this:
{"level":"debug","ts":1623244396.9936051,"logger":"http","msg":"starting server loop","address":"[::]:80","http3":false,"tls":false}
{"level":"info","ts":1623244396.9936795,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["adv-shr-es-https-test-1.westeurope.cloudapp.azure.com"]}
{"level":"info","ts":1623244397.0198913,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
I’m referring to the 2nd line there: enabling automatic TLS certificate management
Why is it missing on the broken VM?
I’m using the same Docker images - 2.4.1. With and without alpine.
