Caddy v2
Running Caddy v2 inside Docker
Nextcloud also running inside Docker
Debian 10
version: "3.7"
build: /opt/docker/caddy/dns-dockerfile
hostname: caddy
- "3000:3000"
- "2023:2023"
- "2024:2024"
- "8126:8126"
- "2003:2003"
- "2004:2004"
- "8125:8125/udp"
- "8083:8083"
- "8082:8082"
- "8125:8125"
- "90:80"
- "25826:25826/udp"
- "8086:8086"
- "8090:8090"
- "8092:8092/udp"
- "8094:8094"
- "9090:9090"
- "9103:9103"
- "9100:9100"
- MY_DOMAIN
- CLOUDFLARE_API_TOKEN
- /opt/docker/caddy/Caddyfile:/etc/caddy/Caddyfile:ro
- /opt/docker/caddy/data:/data
- /opt/docker/caddy/config:/config
default:
external:
email my@email.com
(webconf) {
# Add zstd and gzip compression to requests
encode zstd gzip
# Remove headers (leading "-")
-x-powered-by
# Add common headers for non-reverse_proxy sites
(non_reverse_proxy_headers) {
X-Frame-Options "SAMEORIGIN"
Content-Security-Policy "frame-src 'self'; frame-ancestors 'self'; object-src 'none';"
@cache_css_js {
path_regexp cache_css_js \.(?:css|js)$
@cache_media {
path_regexp cache_media \.(?:jpg|jpeg|gif|png|bmp|ico|swf|xml|ogg|m4a|mp3)$
# 1 week
header @cache_css_js Cache-Control max-age=604800
# 2 weeks
header @cache_media Cache-Control max-age=1209600
cloud.{$MY_DOMAIN} {
reverse_proxy nextcloud:80
header Strict-Transport-Security max-age=31536000;
redir /.well-known/carddav /remote.php/carddav 301
redir /.well-known/caldav /remote.php/caldav 301
import webconf
I can’t get AWS S3 to work as external storage.
With the same environment setup, AWS S3 working with Nextcloud when use with Nginx Proxy Manager.
