Hi,
so I’m using this Caddyfile for Nextcloud, and the official client for desktop works fine. But the mobile client (for Android in my case) only shows the root folder. I can open files, if they are in root, but when I tap on a folder, I only get: Nothing in here. Upload something!
Strangely, I get a similar error when I try to mount the WebDav directly in Gnome Files. Then I get an error message like: HTTP Error: Message Corrupt
So basically only the offical desktop client works.
I tested it with Caddy 0.9.4 (and many older versions), but I haven’t tried setting it up with Nginx or Apache to see, if it’s working at all.
The access.log for the mobile client looks like this:
"PROPFIND /remote.php/webdav/test_folder/ HTTP/1.1" 503 287
The access.log for the WebDav mount in Gnome Files looks like this (I get 5 lines every time):
"PROPFIND /remote.php/webdav/test_folder HTTP/1.1" 207 734
"PROPFIND /remote.php/webdav/test_folder/ HTTP/1.1" 0 13415
It would be really great, if someone could help me
Thanks in advance.
