1. I’m trying to use Caddy with an IP address
I currently have a ZeroSSL certificate assigned for my IP address, and my Caddyfile seems to be configured correctly with the certificate
2. My Log
2024/09/23 06:04:56.385 INFO using adjacent Caddyfile
2024/09/23 06:04:56.386 INFO adapted config to JSON {"adapter": "caddyfile"}
2024/09/23 06:04:56.386 WARN Caddyfile input is not formatted; run 'caddy fmt --overwrite' to fix inconsistencies {"adapter": "caddyfile", "file": "Caddyfile", "line": 2}
2024/09/23 06:04:56.387 INFO admin admin endpoint started {"address": "localhost:2019", "enforce_origin": false, "origins": ["//localhost:2019", "//[::1]:2019", "//127.0.0.1:2019"]}
2024/09/23 06:04:56.387 INFO tls.cache.maintenance started background certificate maintenance {"cache": "0x40005fb600"}
2024/09/23 06:04:56.387 INFO http.auto_https skipping automatic certificate management because one or more matching certificates are already loaded {"domain": "158.101.31.180", "server_name": "srv0"}
2024/09/23 06:04:56.387 INFO http.auto_https enabling automatic HTTP->HTTPS redirects {"server_name": "srv0"}
2024/09/23 06:04:56.387 INFO http enabling HTTP/3 listener {"addr": ":443"}
2024/09/23 06:04:56.388 INFO http.log server running {"name": "srv0", "protocols": ["h1", "h2", "h3"]}
2024/09/23 06:04:56.388 INFO http.log server running {"name": "remaining_auto_https_redirects", "protocols": ["h1", "h2", "h3"]}
2024/09/23 06:04:56.388 INFO http enabling automatic TLS certificate management {"domains": [irrelavant domain"]}
2024/09/23 06:04:56.388 INFO autosaved config (load with --resume flag) {"file": "/root/.config/caddy/autosave.json"}
2024/09/23 06:04:56.388 INFO serving initial configuration
2024/09/23 06:04:56.388 INFO tls.obtain acquiring lock {"identifier": "irrelavant domain"}
2024/09/23 06:04:56.391 INFO tls storage cleaning happened too recently; skipping for now {"storage": "FileStorage:/root/.local/share/caddy", "instance": "272d8f52-9fd8-403e-a214-796ac2bd288e", "try_again": "2024/09/24 06:04:56.391", "try_again_in": 86399.99999968}
2024/09/23 06:04:56.391 INFO tls finished cleaning storage units
2024/09/23 06:04:56.392 INFO tls.obtain lock acquired {"identifier": "irrelavant domain"}
2024/09/23 06:04:56.392 INFO tls.obtain obtaining certificate {"identifier": "irrelavant domain"}
2024/09/23 06:04:56.658 INFO http waiting on internal rate limiter {"identifiers": [irrelavant domain"], "ca": "https://acme-v02.api.letsencrypt.org/directory", "account": ""}
2024/09/23 06:04:56.658 INFO http done waiting on internal rate limiter {"identifiers": ["irrelavant domain"], "ca": "https://acme-v02.api.letsencrypt.org/directory", "account": ""}
2024/09/23 06:04:56.658 INFO http using ACME account {"account_id": "https://acme-v02.api.letsencrypt.org/acme/acct/1961896326", "account_contact": []}
2024/09/23 06:04:56.784 INFO http.acme_client trying to solve challenge {"identifier": "irrelavant domain", "challenge_type": "tls-alpn-01", "ca": "https://acme-v02.api.letsencrypt.org/directory"}
2024/09/23 06:04:56.929 INFO tls served key authentication certificate {"server_name": "irrelavant domain", "challenge": "tls-alpn-01", "remote": "23.178.112.101:51295", "distributed": false}
2024/09/23 06:04:57.199 INFO tls served key authentication certificate {"server_name": "irrelavant domain", "challenge": "tls-alpn-01", "remote": "3.15.28.3:55260", "distributed": false}
2024/09/23 06:04:57.243 INFO tls served key authentication certificate {"server_name": "irrelavant domain", "challenge": "tls-alpn-01", "remote": "18.237.99.175:59338", "distributed": false}
2024/09/23 06:04:57.662 INFO tls served key authentication certificate {"server_name": "irrelavant domain", "challenge": "tls-alpn-01", "remote": "13.61.3.210:63110", "distributed": false}
2024/09/23 06:04:57.828 INFO tls served key authentication certificate {"server_name": "irrelavant domain", "challenge": "tls-alpn-01", "remote": "3.0.249.225:39058", "distributed": false}
2024/09/23 06:04:58.251 INFO http.acme_client authorization finalized {"identifier": "irrelavant domain", "authz_status": "valid"}
2024/09/23 06:04:58.251 INFO http.acme_client validations succeeded; finalizing order {"order": "https://acme-v02.api.letsencrypt.org/acme/order/1961896326/307566350166"}
2024/09/23 06:04:58.657 INFO http.acme_client got renewal info {"names": ["irrelavant domain"], "window_start": "2024/11/21 05:25:57.000", "window_end": "2024/11/23 05:25:57.000", "selected_time": "2024/11/22 14:04:23.000", "recheck_after": "2024/09/23 12:04:58.657", "explanation_url": ""}
2024/09/23 06:04:58.725 INFO http.acme_client got renewal info {"names": ["irrelavant domain"], "window_start": "2024/11/21 05:25:57.000", "window_end": "2024/11/23 05:25:57.000", "selected_time": "2024/11/22 09:38:50.000", "recheck_after": "2024/09/23 12:04:58.725", "explanation_url": ""}
2024/09/23 06:04:58.726 INFO http.acme_client successfully downloaded available certificate chains {"count": 2, "first_url": "https://acme-v02.api.letsencrypt.org/acme/cert/032a1e0be2680b7827d8d1b4ee63495150d7"}
2024/09/23 06:04:58.726 INFO tls.obtain certificate obtained successfully {"identifier": "irrelavant domain", "issuer": "acme-v02.api.letsencrypt.org-directory"}
2024/09/23 06:04:58.726 INFO tls.obtain releasing lock {"identifier": "irrelavant domain"
The notable thing happening in my logs is the following line
http.auto_https skipping automatic certificate management because one or more matching certificates are already loaded {"domain": "158.101.31.180", "server_name": "srv0"}```
Seems like the certificate is already loaded, but I can’t visit the IP address via SSL?
3. Caddy version: v2.8.4
For installing, I just used my package manager. To run Caddy, I edit the Caddyfile over at /etc/caddy/Caddyfile
Contents of my Caddyfile:
158.101.31.180 {
tls /etc/ssl/certs/certificate.crt /etc/ssl/private/private.key
irrelavant domain {
reverse_proxy localhost:8080
a. System environment: Ubuntu
b. Command for running Caddy
sudo systemctl restart caddy
google.com {
Error: Caddyfile:2: Caddyfile input is not formatted; Tip: use '--overwrite' to update your Caddyfile in-place instead of previewing it. Consult '--help' for more options
