Need to block access for a file from external and enable from internal
Currently I have the following in caddyfile
handle /actuator/* {
abort
This currently blocks complete access from internal and external. I need to enable this from internal and disable it from external
No Error
v2.7.6
install caddy package with apt
Debian 10
caddy runs as a service
NA
                abort
Use the remote_ip matcher:
I modified it to below. Actual IP adresses are modified
@actuator {
path /actuator/*
remote_ip 192.0.0.1 192.0.0.2
Still not working. How should I add handle for this ?
Do you mean to invert the condition? Then use not remote_ip
I mean, you’re not giving us enough to go on here. What do you mean it’s “not working”? What did you actually try? Post your entire config, not just a tiny snippet. Show your logs. Make a request with curl -v and show what you get.
