I am new to Caddy, well I have been playing with it for a few weeks now. I have yet to succesfully setup https for applications like nextcloud or authentik. I have been getting rate limited and having to start over multiple times.
I did learn about the staging environment recently so was using that, but still managed to get that rate limited too.
So now I am back to using regular caddy but with no tls verify on nextcloud and authentik, in order to keep my apps running. In 24 hours I will try caddy-staging again without no tls verify and after I have done so more research before I make the same mistakes and get rate limited again (hopefully with help here)
If there is something I should be doing while I do no_tls_verify to ensure it doesn’t keep trying and get me rate limited as soon as it’s lifted.
Note: The current config with no_tls_verify is working fine but obviously I would like to use a proper TLS certificate and remove that option.
I am using docker so do not have record of all my failed attempts. I am not sure if the current logs are helpful as they mention a lot of rate limit errors but they are included. Please let me know if I need to update this post with fresh logs after my rate limit expires.
Due to the limit of characters allowed in post, my error logs are accessible via pastebin
Headless Ubuntu Server Machine running Linux homebase 5.15.0-79-generic #86-Ubuntu SMP Mon Jul 10 16:07:21 UTC 2023 x86_64 x86_64 x86_64 GNU/Linux
Running Docker Compose version v2.17.2
Docker Version Info:
Client:
Version: 20.10.24
API version: 1.41
Go version: go1.20.4
Git commit: 297e128
Built: Wed May 24 23:30:52 2023
OS/Arch: linux/amd64
Context: default
Experimental: true
Server:
Engine:
Version: 20.10.24
API version: 1.41 (minimum version 1.12)
Git commit: 5d6db84
Built: Wed May 24 23:31:22 2023
Experimental: false
containerd:
Version: v1.6.20
GitCommit: 2806fc1057397dbaeefbea0e4e17bddfbd388f38
runc:
Version: 1.1.5
GitCommit:
docker-init:
Version: 0.19.0
GitCommit: de40ad0
sudo docker compose up -d
version: '3.3'
- '80:80'
- '443:443'
- caddy_data:/data
- caddy_config:/config
image: 'caddy:latest'
caddy_data:
caddy_config:
notes.alfredoautomation.com {
reverse_proxy 10.0.0.96:5230
cloud.alfredoautomation.com {
reverse_proxy https://10.0.0.96:444 {
tls_insecure_skip_verify
rss.alfredoautomation.com {
reverse_proxy 10.0.0.96:8085
redir / https://rss.alfredoautomation.com/oauth2/oidc/redirect
sso.alfredoautomation.com {
reverse_proxy https://10.0.0.96:9444 {
photos.alfredoautomation.com {
reverse_proxy http://10.0.0.96:2283
food.alfredoautomation.com {
reverse_proxy 10.0.0.96:4580
Some things I have tried include:
- Switching my Caddyfile config for sso and cloud to http instead of https (while also setting nextcloud and sso to using non ssl ports in their own docker-composes)
- At one point my DNS was hosted via cloudflare and I tried the cloudflare module of caddy.
- For unrelated reasons I am no longer using cloudflare, my DNS is currently with fastmail until I setup my own dns.
- I have switched to the regular caddy instead of caddy-cloudflare
- as mentioned I have tried both staging environment and regular.
- I believe at one point my staging environment was all successful but when I tried again recently it all failed.
