Zero
(Zero)
September 18, 2020, 3:57pm
1
): v1
on Raspbian RPi4
Standard Raspberry Pi Enviornment
N/A
I need to use the http.forwardproxy plugin, which is not supported by Caddy v2. I am in urgent need of a way to install v1 with that plugin on my server.
I’ve tried building from source, but have absolutely no idea what I’m doing it
I’ve tried accessing a link that was created by the old getcaddy.com url but this hasn’t worked form me and gave me a 404
The build instructions are found on github under the v1
branch: GitHub - caddyserver/caddy at v1
Zero
(Zero)
September 18, 2020, 7:29pm
3
How do I specify the plugin?
It’s explained right in those instructions.
Zero
(Zero)
September 18, 2020, 7:56pm
5
The instructions are outdated and not working.
What’s not working? Please be specific.
Zero
(Zero)
September 21, 2020, 6:37pm
7
its says "./main.go:5:2: imported and not used: “github.com/caddyserver/forwardproxy ” and then doesnt build anything
matt
(Matt Holt)
September 21, 2020, 6:40pm
8
The instructions are right. What’s your main.go file?
Zero
(Zero)
September 21, 2020, 7:11pm
9
i made a folder with it in my home directory
Zero
(Zero)
September 21, 2020, 7:14pm
11
the main.go file
package main
import (
"github.com/caddyserver/caddy/caddy/caddymain"
"github.com/caddyserver/forwardproxy"
func main() {
// optional: disable telemetry
// caddymain.EnableTelemetry = false
caddymain.Run()
matt
(Matt Holt)
September 21, 2020, 7:15pm
12
Ah, you missed this part in the instructions:
// plug in plugins here, for example:
// _ "import/path/here"
Note the _
omitted in your file.
Zero
(Zero)
September 21, 2020, 7:20pm
13
okay that fixed that problem, but now when i try to run caddy it gives me
panic: qtls.ConnectionState not compatible with tls.ConnectionState
matt
(Matt Holt)
September 21, 2020, 7:22pm
14
Unfortunately our HTTP/3 dependency does not support Go 1.15; you’ll have to downgrade to Go 1.14 or remove the code that does HTTP/3.
Zero
(Zero)
September 21, 2020, 8:14pm
16
okay got most everything working but now im getting:
Sep 21 21:13:00 carbon caddy[2076]: 2020/09/21 21:13:00 [ERROR][exportcloud.net] failed to obtain certificate: acme: error: 429 :: POST :: https://acme-v02.api.letsencrypt.org/acme/new-order :
Sep 21 21:13:01 carbon caddy[2076]: 2020/09/21 21:13:01 [INFO] [exportcloud.net] acme: Obtaining bundled SAN certificate
Zero
(Zero)
September 24, 2020, 7:30pm
18
@matt I really need a solution
Mohammed90
(Mohammed Al Sahaf)
September 24, 2020, 8:19pm
19
Can you please share more details? E.g. your Caddyfile, system setup, more log lines, etc.
I think your log line was truncated, so it’s hiding the real error message. Please make sure that whatever terminal program you’re using doesn’t cut off the ends of the lines. less
usually does the job pretty well.
system
(system)
Closed
October 18, 2020, 3:57pm
21
