Need help converting an nginx config
I’m usually familiar with caddyfiles but this one looks complicated. Any help appreciated.
nginx config file
You can use the nginx-adapter, but it’s best-effort and will only convert it to JSON. So you’ll have to review it and fix parts of it by hand.
I took a shot at it with the adapter and this is the output:
  "apps": {
    "http": {
      "servers": {
        "server_0": {
          "listen": [
            ":80",
            "[::]:80"
          "routes": [
              "match": [
                  "host": null
              "handle": [
                  "handler": "file_server",
                  "index_names": [
                    "index.html",
                    "index.htm",
                    "index.nginx-debian.html"
                  "root": "/var/www/html"
              "match": [
                  "host": [
                    "index.torrust-demo.com"
                  "path": [
                    "/api/v1/proxy*"
              "handle": [
                  "handler": "subroute",
                  "routes": [
                      "handle": [
                          "routes": [
                              "handle": [
                                  "handler": "rewrite",
                                  "uri": "$request_uri"
                              "match": [
                                  "path_regexp": {
                                    "pattern": "^"
                          "routes": [
                              "handle": [
                                  "uri": "$1"
                              "match": [
                                  "path_regexp": {
                                    "pattern": "^/api(/.*)"
                          "handler": "reverse_proxy",
                          "headers": {
                            "request": {
                              "set": {
                                "Host": [
                                  "{http.reverse_proxy.upstream.host}"
                          "upstreams": [
                              "dial": "tcp/index:3001"
                      "match": [
                          "path": [
                            "/api/v1/proxy*"
              "match": [
                  "host": [
                  "path": [
                    "/api/*"
              "handle": [
                  "routes": [
                      "handle": [
                          "routes": [
                              "handle": [
                                  "uri": "/$1"
                              "match": [
                                  "path_regexp": {
                                    "pattern": "^/api/(.*)$"
                          "headers": {
                            "request": {
                              "set": {
                                "Host": [
                          "upstreams": [
                      "match": [
                          "path": [
                            "/api/*"
              "match": [
                  "host": [
                  "path": [
              "handle": [
                  "routes": [
                      "handle": [
                          "headers": {
                            "request": {
                              "set": {
                                "Host": [
                          "upstreams": [
                              "dial": "tcp/index-gui:3000"
                      "match": [
                          "path": [
              "match": [
                  "host": [
                  "path_regexp": {
                    "pattern": "/.well-known/acme-challenge"
              "handle": [
                  "routes": [
                      "handle": [
                      "match": [
                          "path_regexp": {
                          "remote_ip": {
                            "ranges": [
                              "0.0.0.0:0",
                              "::/0"
              "match": [
                  "host": null
              "handle": [
                  "index_names": [
                    "index.html",
                    "index.htm",
              "match": [
                  "host": [
                    "tracker.torrust-demo.com"
                  "path": [
                    "/api/*"
              "handle": [
                  "routes": [
                      "handle": [
                          "headers": {
                            "request": {
                              "set": {
                                "Host": [
                          "upstreams": [
                              "dial": "tcp/tracker:1212"
                      "match": [
                          "path": [
                            "/api/*"
              "match": [
                  "host": [
                  "path": [
              "handle": [
                  "routes": [
                      "handle": [
                          "headers": {
                            "request": {
                              "set": {
                                "Host": [
                          "upstreams": [
                              "dial": "tcp/tracker:7070"
                      "match": [
                          "path": [
              "match": [
                  "host": [
                  "path_regexp": {
              "handle": [
                  "routes": [
                      "handle": [
                      "match": [
                          "path_regexp": {
                          "remote_ip": {
                            "ranges": [
                              "0.0.0.0:0",
                              "::/0"
