Multiple format directives inside log section
v2.4.1 h1:kAJ0JB5Xk5gPdTH/27S5cyoMGqD5lBAe9yZ8zTjVJa0=
(docker image caddy:alpine)
(default entrypoint)
Docker
docker run -d -p 80:80 caddy:apline
No additional files
	auto_https off
	root * /usr/share/caddy
	try_files {path} /index.html
		output stdout
		format filter {
			wrap json
			fields {
				common_log delete
				resp_headers delete
				request>headers>Accept delete
		format json {
			time_format iso8601
			time_key timestamp
I want to change some log fields and delete another ones. But the only last format directive takes precedence
{"level":"info","timestamp":"2021-05-30T17:11:27.348Z","logger":"http.log.access.log0","msg":"handled request","request":{"remote_addr":"172.17.0.1:63574","proto":"HTTP/1.1","method":"GET","host":"127.1","uri":"/","headers":{"User-Agent":["curl/7.64.1"],"Accept":["*/*"]}},"common_log":"172.17.0.1 - - [30/May/2021:17:11:27 +0000] \"GET / HTTP/1.1\" 200 3192","duration":0.0004962,"size":3192,"status":200,"resp_headers":{"Server":["Caddy"],"Etag":["\"qtvplx2go\""],"Content-Type":["text/html; charset=utf-8"],"Last-Modified":["Sat, 29 May 2021 17:22:45 GMT"],"Accept-Ranges":["bytes"],"Content-Length":["3192"]}}
I tried use comma between format directives but got syntax error obviously
Put your json format settings under the wrap. The filter formatter wraps another format which is nested within it.
		output stdout
		format filter {
			wrap json {
				time_format iso8601
				time_key timestamp
			fields {
				common_log delete
				resp_headers delete
Thank you, @francislavoie! It works!
