I think to integrate external auth mechanism like keycloak/ldap/… into caddy
I have only seen basic auth in the user doc.
Is there another auth solution for caddy?
BR Aleks
BR Aleks
Hello Aleks,
Good question!
I haven’t seen plugins to do this, but I think it’s doable if anyone feels inclined to make a plugin for it.
Well. I have no glue about go so it’s a good reason to start with the language
Can I start with the basicauth as skeleton?
Is there a doc for ‘create a plugin/add-on’ for caddy something like this.
http://httpd.apache.org/docs/2.4/developer/API.html
Is there a doc fo the hooks which caddy provides?
Sure is! https://github.com/mholt/caddy/wiki/Extending-Caddy
If you need to learn Go, start here, in this order (my recommendation):
Auth can be kind of tricky in any language; make sure to have others vet your code as well!
thanks for the links, I will take a look.
As you can assume it will take some time
