Module not registered: dns.providers.cloudflare
I am trying to enable the Cloudflare DNS module but constantly get a ‘module not registered’ error.
merc@caddy:~$ sudo caddy reload --config /etc/caddy/Caddyfile
2023/05/11 07:30:52.565	INFO	using provided configuration	{"config_file": "/etc/caddy/Caddyfile", "config_adapter": ""}
Error: adapting config using caddyfile: parsing caddyfile tokens for 'acme_dns': /etc/caddy/Caddyfile:2 - Error during parsing: getting module named 'dns.providers.cloudflare': module not registered: dns.providers.cloudflare
v2.6.4
Installed following recommended sudo apt install sudo method, then replaced caddy binary in both /bin and /usr/bin with downloaded version after selection amd64 arch/cloudflare module from download page. Then rebooted.
Ubuntu 22 x86_64
Caddy is started automatically by service created with apt install. But error appears each time I run:
merc@caddy:/$ sudo systemctl status caddy
× caddy.service - Caddy
     Loaded: loaded (/lib/systemd/system/caddy.service; enabled; vendor preset: enabled)
     Active: failed (Result: exit-code) since Thu 2023-05-11 07:30:08 UTC; 22min ago
    Process: 598 ExecStart=/usr/bin/caddy run --environ --config /etc/caddy/Caddyfile (code=exited, status=1/FAILURE)
   Main PID: 598 (code=exited, status=1/FAILURE)
        CPU: 108ms
May 11 07:30:08 lnbits caddy[598]: LOGNAME=caddy
May 11 07:30:08 caddy caddy[598]: USER=caddy
May 11 07:30:08 caddy caddy[598]: INVOCATION_ID=e38cb54c6a3547a8aeaad0feefebd320
May 11 07:30:08 caddy caddy[598]: JOURNAL_STREAM=8:19091
May 11 07:30:08 caddy caddy[598]: SYSTEMD_EXEC_PID=598
May 11 07:30:08 caddy caddy[598]: {"level":"info","ts":1683790208.881809,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_ada>
May 11 07:30:08 caddy caddy[598]: Error: adapting config using caddyfile: parsing caddyfile tokens for 'acme_dns': /etc/caddy/Caddyfile:2 - Error during parsi>
May 11 07:30:08 caddy systemd[1]: caddy.service: Main process exited, code=exited, status=1/FAILURE
May 11 07:30:08 caddy systemd[1]: caddy.service: Failed with result 'exit-code'.
May 11 07:30:08 caddy systemd[1]: Failed to start Caddy.
merc@caddy:/$ sudo caddy reload --config /etc/caddy/Caddyfile
2023/05/11 07:55:03.729	INFO	using provided configuration	{"config_file": "/etc/caddy/Caddyfile", "config_adapter": ""}
# caddy.service
# for your installation.
Type=notify
PrivateDevices=yes
        acme_dns cloudflare <token>
:8080
reverse_proxy :5000
Please can you share the output of /usr/bin/caddy list-modules
It doesn’t appear:
merc@caddy:~$ caddy list-modules
admin.api.load
admin.api.metrics
admin.api.pki
admin.api.reverse_proxy
caddy.adapters.caddyfile
caddy.config_loaders.http
caddy.listeners.http_redirect
caddy.listeners.tls
caddy.logging.encoders.console
caddy.logging.encoders.filter
caddy.logging.encoders.filter.cookie
caddy.logging.encoders.filter.delete
caddy.logging.encoders.filter.hash
caddy.logging.encoders.filter.ip_mask
caddy.logging.encoders.filter.query
caddy.logging.encoders.filter.regexp
caddy.logging.encoders.filter.rename
caddy.logging.encoders.filter.replace
caddy.logging.encoders.json
caddy.logging.writers.discard
caddy.logging.writers.file
caddy.logging.writers.net
caddy.logging.writers.stderr
caddy.logging.writers.stdout
caddy.storage.file_system
events
http
http.authentication.hashes.bcrypt
http.authentication.hashes.scrypt
http.authentication.providers.http_basic
http.encoders.gzip
http.encoders.zstd
http.handlers.acme_server
http.handlers.authentication
http.handlers.copy_response
http.handlers.copy_response_headers
http.handlers.encode
http.handlers.error
http.handlers.file_server
http.handlers.headers
http.handlers.map
http.handlers.metrics
http.handlers.push
http.handlers.request_body
http.handlers.reverse_proxy
http.handlers.rewrite
http.handlers.static_response
http.handlers.subroute
http.handlers.templates
http.handlers.tracing
http.handlers.vars
http.ip_sources.static
http.matchers.expression
http.matchers.file
http.matchers.header
http.matchers.header_regexp
http.matchers.host
http.matchers.method
http.matchers.not
http.matchers.path
http.matchers.path_regexp
http.matchers.protocol
http.matchers.query
http.matchers.remote_ip
http.matchers.vars
http.matchers.vars_regexp
http.precompressed.br
http.precompressed.gzip
http.precompressed.zstd
http.reverse_proxy.selection_policies.cookie
http.reverse_proxy.selection_policies.first
http.reverse_proxy.selection_policies.header
http.reverse_proxy.selection_policies.ip_hash
http.reverse_proxy.selection_policies.least_conn
http.reverse_proxy.selection_policies.random
http.reverse_proxy.selection_policies.random_choose
http.reverse_proxy.selection_policies.round_robin
http.reverse_proxy.selection_policies.uri_hash
http.reverse_proxy.transport.fastcgi
http.reverse_proxy.transport.http
http.reverse_proxy.upstreams.a
http.reverse_proxy.upstreams.multi
http.reverse_proxy.upstreams.srv
pki
tls
tls.certificates.automate
tls.certificates.load_files
tls.certificates.load_folders
tls.certificates.load_pem
tls.certificates.load_storage
tls.client_auth.leaf
tls.get_certificate.http
tls.get_certificate.tailscale
tls.handshake_match.remote_ip
tls.handshake_match.sni
tls.issuance.acme
tls.issuance.internal
tls.issuance.zerossl
tls.stek.distributed
tls.stek.standard
  Standard modules: 100
  Non-standard modules: 0
  Unknown modules: 0
Now you have the answer why the message is in the log :smiley: .
The solution is to make again the download on Download Caddy or build your own binary with xcaddy
So you are saying that the download page doesn’t work as intended?
Well no :slight_smile: just repeat the message from the download page.
:warning: Due to multiple outstanding bugs in the go command, we are aware that some downloads may hang or fail. In the meantime, you can download Caddy from the latest release on GitHub, or use xcaddy for custom builds. (Remember, this download page comes with no guarantees or SLAs.) Sorry for the inconvenience.
I would try to download as long as the module is in the binary or build my own based on xcaddy.
Thanks for your suggestions @al-caddyserver. It seems the curl download direct to the server wasn’t grabbing the correct version. When I did it manually on my Mac and SCP’ed it to the server the module now shows.
admin.api.load
admin.api.metrics
admin.api.pki
caddy.listeners.tls
events
http
http.encoders.gzip
http.encoders.zstd
http.handlers.error
http.handlers.map
http.handlers.push
http.handlers.vars
http.matchers.file
http.matchers.host
http.matchers.not
http.matchers.path
http.matchers.query
http.matchers.vars
pki
tls
tls.issuance.acme
tls.stek.standard
  Non-standard modules: 1
  Unknown modules: 0
