Caddy is throwing an error when attempting to start
"module not registered: dns.providers.cloudflare"
× caddy.service - Caddy
Loaded: loaded (/lib/systemd/system/caddy.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Fri 2024-08-16 02:59:01 UTC; 3s ago
Process: 4867 ExecStart=/usr/bin/caddy run --environ --config /etc/caddy/Caddyfile (code=exited, status=1/FAILURE)
Main PID: 4867 (code=exited, status=1/FAILURE)
CPU: 60ms
Aug 16 02:59:01 media caddy[4867]: LOGNAME=caddy
Aug 16 02:59:01 media caddy[4867]: USER=caddy
Aug 16 02:59:01 media caddy[4867]: INVOCATION_ID=75a068766051471d83c6e1f0384633e0
Aug 16 02:59:01 media caddy[4867]: JOURNAL_STREAM=8:46269
Aug 16 02:59:01 media caddy[4867]: SYSTEMD_EXEC_PID=4867
Aug 16 02:59:01 media caddy[4867]: {"level":"info","ts":1723777141.96471,"msg":"using config from file","file":"/etc/caddy/Caddyfile"}
Aug 16 02:59:01 media caddy[4867]: Error: adapting config using caddyfile: parsing caddyfile tokens for 'tls': getting module named 'dns.providers.cloudflare': module not registered: dns.providers.cloudflare, at /etc/caddy/Caddyfile:4
Aug 16 02:59:01 media systemd[1]: caddy.service: Main process exited, code=exited, status=1/FAILURE
Aug 16 02:59:01 media systemd[1]: caddy.service: Failed with result 'exit-code'.
Aug 16 02:59:01 media systemd[1]: Failed to start Caddy.
v2.8.4
apt on an ubuntu server, used xcaddy to install the cloudflare plugin
Ubuntu LTS
sudo apt update
sudo apt install caddy
