{I did not use the help-template because I’m looking for a general idea how to get MinIO+Caddy working.}
Hi,
has anyone made a Caddy reverse-proxy work with MinIO (https://min.io/) and can provide me with a working Caddyfile?
The tutorial at MinIO | Setup Caddy proxy with MinIO - Cookbook/Recipe is outdated (Caddy v1).
Background:
I’m trying to provide a secure connection to my MinIO server via Caddy with a simple
reverse_proxy localhost:9000
in the Caddyfile. This works well for other services on other ports, just not for MinIO.
When you call MinIO through a browser at port 9000, it redirects you to another port (9001) where a web-UI is provided. The redirect works behind the Caddy-reverse-proxy, but this connection is marked “not secure” by the browser.
I am wondering now whether the secure connection to the original port is working and only the redirect opens a new, unsafe connection in the browser, or whether MinIO is generally not working with a (Caddy) reverse-proxy.
