v2.2.0
caddy-api on ubuntu vm
ubuntu 20.04
systemctl start caddy-api
# caddy-api.service
# For using Caddy with its API.
# This unit is "durable" in that it will automatically resume
# the last active configuration if the service is restarted.
After=network.target
Environment="CONSUL_HTTP_ADDR=https://consul01p.net.work:8500"
ExecStart=/usr/bin/caddy run --environ --resume
N/A
I’m not quite sure if this is possible in caddy but I’m moving my our internal rproxy solution from nginx to caddy and I’m stuck on one configuration and I’m not quite sure it is possible to do the same in caddy, here is the “tricky” part (for me at least)
if ($args ~ entryPoint=campaign_trackerv2) {
rewrite ^/(.*)$ /$1 last;
The rest of the nginx configuration is already adapt to caddy as it is basic reverse proxy stuff.
I am not the original editor of the nginx conf but already been told it is mandatory…
I tried to use nginx-adapter but does not seem to work anymore.
Thanks in advance for your help.
Regards,
