Hi,
I am using Caddy2 on Ubuntu 20.04 and running caddy by hand
caddy run --config /etc/caddy/Caddyfile &
I would like to run Mattermost but converting nginx config file to caddy2 it’s a bit above my expertise level
If you would like to help me and I suppose more people that would like to run Mattermost with Caddy, please take a look at the belog nginx config
THANK YOU!
upstream mattermost {
server localhost:8065;
keepalive 32;
proxy_cache_path /var/cache/nginx levels=1:2 keys_zone=mattermost_cache:10m max_size=3g inactive=120m use_temp_path=off;
server {
listen 80;
server_name mattermost.linuxbuz.com;
location ~ /api/v[0-9]+/(users/)?websocket$ {
proxy_set_header Connection “upgrade”;
client_max_body_size 50M;
proxy_set_header Host $http_host;
proxy_set_header X-Forwarded-Proto $scheme;
proxy_set_header X-Frame-Options SAMEORIGIN;
proxy_buffers 256 16k;
proxy_buffer_size 16k;
client_body_timeout 60;
send_timeout 300;
lingering_timeout 5;
proxy_connect_timeout 90;
proxy_send_timeout 300;
proxy_read_timeout 90s;
proxy_pass http://mattermost;
location / {
proxy_set_header Connection “”;
proxy_read_timeout 600s;
proxy_cache mattermost_cache;
proxy_cache_revalidate on;
proxy_cache_min_uses 2;
proxy_cache_use_stale timeout;
proxy_cache_lock on;
proxy_http_version 1.1;
