What are the Markdown specs for Caddy v2? Is it only John Gruber’s baseline Markdown, or does it include support for one of the extended specs, and of so, which one(s)?
Is there also a way to manually extend the capabilities of the built-in Markdown support?
I’m wondering if I can get by with the built-in spec, or if I need to use a Markdown-compatible CMS like Pico or something else to get some of the extended syntax features.
