1. My Caddy version (caddy version
Version 1.0.4
I’m setting up a small blog. Directory structure looks like this:
- orange.css # my CSS
- index.html # this is where the problem is happening
- blogpost.html # a template for my blogposts
- /blog # the blogpost .md files
+ - markdowntest.md # an example .md file
I’m running Arch on a VPS, Linux kernel 4.9, systemd 244.1-1.
cd /path/to/my/htmldir
sudo caddy
I do not know where to look for these files, and haven’t set them up.
My caddyfile is:
lambda-delta.tk
markdown /blog {
css /orange.css
template blogpost.html
templates
I am trying to generate a list of files in /blog, linked to those files, with the contents of the file afterward–basically, an index for my blog posts. However, when I try to .Include or .Markdown a file inside of the range I’m using to list all the files, I get a 500 internal server error.
Here’s the templating I’m doing in index.html:
<div class="title">Blog entries:</div>
<div class="entry">
{{.Include "blog/markdowntest.md"}} <!-- .Include and .Markdown both work here... -->
{{range $field := .Files "blog"}}
{{ $path := "blog/" }}
<a href="{{$path}}{{$field}}"></a> - {{.Include "blog/markdowntest.md"}} <!-- But using a .Include here causes a 500 Internal Server Error when I load the page. -->
{{end}}</div>
In addition, trying to do any kind of string concatenation–such as {{$path := "blog/" + $field}}
–also causes a 500 Internal Server Error.
Caddy starts without issues, outside of an inode complaint:
ns507181% sudo caddy
[sudo] password for dbrz:
Serving HTTP on port 80
http://lambda-delta.tk
Serving HTTPS on port 443
https://lambda-delta.tk
WARNING: File descriptor limit 1024 is too low for production servers. At least 8192 is recommended. Fix with `ulimit -n 8192`.
There is no additional output after I attempt to load index.html.
Running with -log log.txt
provides the following output in log.txt:
ns507181% cat log.txt
2020/04/12 01:38:23 [INFO] Caddy version: v1.0.4
2020/04/12 01:38:23 [INFO][cache:0xc0001a2b40] Started certificate maintenance routine
2020/04/12 01:38:23 [INFO] Serving https://lambda-delta.tk
2020/04/12 01:38:23 [INFO] Serving http://lambda-delta.tk
2020/04/12 01:40:33 [INFO] SIGINT: Shutting down
2020/04/12 01:40:33 [INFO][cache:0xc0001a2b40] Stopped certificate maintenance routine
Again, nothing changes after I try to load the page. No additional output.
I’ve narrowed it down to concatenation or running an .Include or .Markdown inside the range. I’ve gotten it working without the “preview”, and can make a list of links that go where they’re supposed to, but if I try to do anything further than that it falls apart.
Caddy V1 template actions documentation:
https://caddyserver.com/v1/docs/template-actions
Go Template docs:
