the template documentation says:
Map keys to values: (useful in advanced cases, with subtemplates, etc.)
{{.Map “key1” “value1” “key2” “value2”}}
But when I try running that code, it actually outputs map[key1:value1 key2:value2]
to the page. If I assign the map {{$foo := .Map "key1" "value1" "key2" "value2"}}
that stops the output, but then the values aren’t assigned to the global .Map
dict.
page.html
{{.Include "base.html"}}
base.html
foo is <b>{{.Map}}</b>
output is: foo is <b>map[]</b>
And I can’t access $foo across templates. Is there any further clarity/examples around what the documentation means when it says “useful in advanced cases, with subtemplates, etc.”?
