Making remote caddy webserver
I can run my server that serves a php file on localhost but when I replace the localhost with my IP, I still can’t acces the webserver via google on another network. My caddy file compiles and caddy does run but I still can’t vistit the webserver.
Can anyone help me in getting the server online for external use?
This is my caddyfile:
:8000
php_fastcgi unix//run/php/php8.1-fpm.sock {
index test.php
root /var/www/html/
no error message
I installed caddy by following the caddy documentation for ubuntu
Please completely fill out the help topic template as per the forum rules.
What’s your Caddy version? How did you install Caddy? What’s in your logs? Please mind your post’s formatting, use code blocks for your config and/or logs.
Don’t just say “no error message”, that’s not useful. We need detail to understand your problem and what you tried. Show an example request with curl -v.
