Now, between Caddy and users, the responses can be uncompressed / gzipped in case users ask for it. But, between Caddy and upstream, I want to have LZ4 compression. Upstream can return LZ4 responses all the time. Caddy would have to decompress it and handle it as it would a normal request before sending to the user.
What’s the best way to achieve this functionality? Is that baked in? Or, would it require a plugin?
As far as I know, no HTTP servers or browsers supports LZ4 compression for HTTP. I can’t find any information about any that do, anyway. I don’t see a known value for Content-Encoding for LZ4. See Content-Encoding - HTTP | MDN for example.
Yeah, LZ4 isn’t as popular as it should be. But, if I were to do LZ4 between upstream and Caddy, what’s the best way? Would a plugin be the right way to do this?
But Caddy’s encoder is pluggable. See this plugin for example which adds brotli compression (which also isn’t viable to include in Caddy because it doesn’t perform well enough):
