proxmox
systemctl start caddy
Type=notify
hvgh.de {
reverse_proxy bbb
I run caddy on the proxmox host. On this host I have an lxc container (hostname bbb) with ubuntu_18.04 on which I try to install bigbluebutton. The bbb install tries to use certbot for a certificate, I get the following error:
Saving debug log to /var/log/letsencrypt/letsencrypt.log
How would you like to authenticate with the ACME CA?
1: Spin up a temporary webserver (standalone)
2: Place files in webroot directory (webroot)
Select the appropriate number [1-2] then [enter] (press 'c' to cancel): 1
Plugins selected: Authenticator standalone, Installer None
Obtaining a new certificate
Performing the following challenges:
http-01 challenge for hvgh.de
Waiting for verification...
Cleaning up challenges
Failed authorization procedure. hvgh.de (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching https://hvgh.de/.well-known/acme-challenge/llWQ4CgibS8GnNWDplcq5gJDAEt23U_6b2O59rFFCbM: Redirect loop detected
IMPORTANT NOTES:
- The following errors were reported by the server:
Domain: hvgh.de
Type: connection
Detail: Fetching
To fix these errors, please make sure that your domain name was
entered correctly and the DNS A/AAAA record(s) for that domain
contain(s) the right IP address. Additionally, please check that
your computer has a publicly routable IP address and that no
firewalls are preventing the server from communicating with the
client. If you're using the webroot plugin, you should also verify
that you are serving files from the webroot path you provided.
