how can we rewrite the following load balancing config with json api?
proxy / http://localhost:15984 http://localhost:25984 http://localhost:35984 {
policy round_robin
health_check /_up
health_check_duration 5s
try_interval 500ms
keepalive 0
As a first step, you can rewrite that config with Caddy v2’s Caddyfile. See the reverse_proxy
docs here:
Then, you can use the caddy adapt
command to see what JSON it outputs. You can then use that to see which JSON path you need to modify with the API.
system
(system)
closed
#4
