Hi! As I documented in this post, I was using a Caddy plugin to save certificate information in a database. This very roughly worked as follows:
- Added an event fired when a certificate is obtained
- Caddy plugin listens for that event and saves details to a database
Unfortunately, with certificates now obtained by CertMagic, I’m in a tricky situation. I can’t use a Caddy plugin, as CertMagic doesn’t know about Caddy and can’t emit an event. Additionally, I can’t make a CertMagic plugin, as those don’t exist.
Any ideas? My only thought is to build my database integration directly into CertMagic.
