I’m trying to figure out why the following is in the code
https://github.com/mholt/caddy/blob/master/caddytls/handshake.go#L333
It seems that you’re rate limiting to one certificate issued every 10 minutes after the first 10?
Ok. Why one every 10 minutes after the first 10? There isn’t any way to configure it right?
To prevent abuse. And no, it can’t be configured. But you can use the ask
subdirective to do your own abuse prevention.
Hey @matt ! This feature is really exciting for a project that I’m working on. I want to enable HTTPS for the custom domains added by users to my SaaS app.
I was just wondering if I am ok to tweak these rate limits by modifying the source, or if that is a very bad idea? In particular:
The above would be following these assumptions:
ask
endpoint will only return a 200 if the DNS is setup correctly.ask
endpoint, say five domain changes per user per week.I understand why the rate limits are in place in the source and am not suggesting that these are changed for those using Caddy out of the box. I was just wondering if changing them for our own usage is ok or if we should be looking at making a custom Caddyfile loader instead?
Just my 2c… There’s two questions there - can you, and should you?
Firstly, yeah, sure - the code is all Apache licensed, you’re allowed to modify it for your usage.
Secondly, it’s there to protect both LetsEncrypt’s endpoint from abuse, and Caddy’s users from rate limits - so as long as you’re aware of the responsibility you’re taking into your own hands - that is, to be fair to LE’s ACME server, and to avoid being rate-limited - the choice is ultimately yours.
Thanks @Whitestrake, that makes sense.
If you don’t mind me rephrasing the question: would you, wanting to achieve the feature I am suggesting, do what I am proposing?
My main reason for asking here is because I appreciate the limit is there for a reason and am wondering if there is a better way. Based on what you have said I think I am making the right decision here but I would appreciate any feedback if you disagree
Yeah, probably. I don’t think there are two ways about it; if you need more certs than the current cap, you need to remove the cap, and the above code is where you do it. The technical part is pretty straight-forward.
The rate limits are all published, so if you make sure the endpoint you’re using for ask
validation keeps those in mind, you’ll have no problems.
I would just set up an ask
endpoint that does the rate limiting or whatever other checks you want, then you can use stock binaries/source code. Those limits you proposed sound fine; it ultimately depends on your threat model – just having some limits in place is a huge net positive, so that’s good.
