I am using on_demand directive under https:// block along with ask url. I am seeing zerossl certificate issuance instead of letsencrypt.
If i use acme_ca directive, Then things work absolutely fine and it starts providing letsencrypt certificates. But ones which were generated previously using zerossl dont load and new certificates via letsencrypt gets issued again.
Here is the acme_ca directive
acme_ca https://acme-v02.api.letsencrypt.org/directory
How can we fix below error ?
How can we test whether on_demand failover is working ?
How can we ensure certificates issued by one CA doesn’t get generated by another CA ?
How can we force on_demand directive to issue zerossl first then letsencrypt ?
{"level":"error","ts":1690800598.3533516,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"test24.example.com","issuer":"-admin@example.com","error":"registering account [mailto:admin@example.com] with server: provisioning client: response Content-Type is text/html but target container is not io.Writer: *acme.Directory"}
Note: Domain not disclosed due to a nda
apt install caddy -y
Ubuntu 22.04 on ec2
systemctl start caddy
NA
cert_issuer acme example@example.com
cert_issuer zerossl EXAMPLEKEY
output file /var/log/caddy/caddy.log
email example@example.com
storage redis {
host "127.0.0.1"
port 6379
address "127.0.0.1:6379"
username ""
password "example"
db 1
key_prefix "caddytls"
value_prefix "caddy-storage-redis"
timeout 30
tls_enabled "false"
tls_insecure "true"
on_demand_tls {
ask https://www.example.com/validator
interval 2m
burst 30
https://
on_demand
