LetsEncrypt ISRG Root X2
Hello,
I have an embedded device (esp) which needs TLS. I want to use the ISRG Root X2 for verification, because ECDSA uses less ressources/is more efficient.
I configured caddy to use it with:
{ preferred_chains { root_common_name “ISRG Root X2” } }
I get a certificate from now and the browser says it is okay, but from my device I get an handshake error.
My guess is that caddy is not serving the full chain.
mbedtls_ssl_handshake returned -0x2700
Which means: “certificate verification failed, e.g., CRL, CA or signature check failed”
It looks like something is wrong with the cert chain, I made an check with openssl s_client -connect xx.yy:443 -showcert which says:
No client certificate CA names sent
Peer signing digest: SHA256
Peer signature type: ECDSA
Server Temp Key: X25519, 253 bits
SSL handshake has read 1983 bytes and written 380 bytes
Verification error: unable to get local issuer certificate
New, TLSv1.3, Cipher is TLS_AES_128_GCM_SHA256
Server public key is 256 bit
Secure Renegotiation IS NOT supported
Compression: NONE
Expansion: NONE
No ALPN negotiated
Early data was not sent
Verify return code: 20 (unable to get local issuer certificate)
Post-Handshake New Session Ticket arrived:
SSL-Session:
    Protocol  : TLSv1.3
    Cipher    : TLS_AES_128_GCM_SHA256
    Session-ID: 6F411F858DDEC88EC0880CB7AF0CBBD860799953FD911B9C49C1F30E343FEE93
    Session-ID-ctx:
    Resumption PSK: 027408C0104A071DCADBA2CF539B4C5904E9F37A8A8581E6AAC35AEF3C777148
    PSK identity: None
    PSK identity hint: None
    SRP username: None
    TLS session ticket lifetime hint: 604800 (seconds)
    TLS session ticket:
    0000 - dc db 45 ec 66 82 05 cc-3d 14 fb 6e 03 0b a9 85   ..E.f...=..n....
    0010 - d2 45 25 e7 70 58 19 d5-11 20 8a 21 03 f1 1f 1d   .E%.pX... .!....
    0020 - f6 eb 46 e9 8f 15 5a 3d-9b 1d 3f f3 1d 25 38 7a   ..F...Z=..?..%8z
    0030 - 0a 40 89 f9 be 8a 3a c8-69 80 9a 83 5b c3 87 e6   .@....:.i...[...
    0040 - 09 dd 5e 2b e0 a2 c9 cf-94 95 94 21 48 6e 8e fb   ..^+.......!Hn..
    0050 - 05 42 1a f8 26 32 de 80-72 60 a5 74 d4 5a fd 9d   .B..&2..r`.t.Z..
    0060 - 83 6e 16 e8 24 24 a1 26-64                        .n..$$.&d
    Start Time: 1753885066
    Timeout   : 7200 (sec)
    Extended master secret: no
    Max Early Data: 0
v2.10.0
Debian
True, Caddy does not serve the full chain. Doing so is usually pointless. But you can install the root onto your device and it will work.
