1. Output of caddy version
v2.6.1 h1:EDqo59TyYWhXQnfde93Mmv4FJfYe00dO60zMiEt+pzo=
amazon linux 2
caddy run --config caddyfile.json
I wanted to find out how to insert some variability in the renewal of domain certificates. If I have 200 certificates that will need to be renewed in a small amount of time, is there a way to throw some randomness on when caddy begins trying to renew them?
matt
(Matt Holt)
October 4, 2022, 9:27pm
2
Not currently. If a renewal fails, Caddy will simply back off and retry.
Edit: However, you can set the renewal_window_ratio
parameter:
But this will not really “throw some randomness” on it, unless you randomize that ratio I guess?
Also FWIW, 200 is not that many.
Some users of Caddy manage tens of thousands of certificates.
You won’t hit any rate limits with 200; Caddy has its own internal rate limit and has a bunch of fallback mechanisms in case issuance attempts fail.
system
(system)
Closed
November 3, 2022, 8:55pm
4
