1. Output of caddy version
v2.5.1 (Upgrade planned)
Systemd as caddy user
AWS EC2 Pool
Linux 5.13.0-1023-aws #25~20.04.1-Ubuntu SMP 2022 x86_64 x86_64 x86_64 GNU/Linux
service caddy start
After=network-online.target remote-fs.target nginx.service
Requires=nginx.service
BindsTo=nginx.service
Type=notify
Restart=on-abort
Environment=CADDYPATH=/etc/ssl/caddy/v2
; Always set "-root" to something safe in case it gets forgotten in the Caddyfile.
ExecStart=/usr/bin/caddy run --environ --config /etc/caddy/Caddyfile_v2 -watch
ExecReload=/usr/bin/caddy reload --config /etc/caddy/Caddyfile_v2 -watch
; Use graceful shutdown with a reasonable timeout
KillMode=mixed
KillSignal=SIGQUIT
; Unmodified caddy is not expected to use more than that.
LimitNPROC=2048
; Use a minimal /dev (May bring additional security if switched to 'true', but it may not work on Raspberry Pi's or other devices, so it has been disabled in this dist.)
PrivateDevices=false
ProtectHome=true
; … except /etc/ssl/caddy, because we want Letsencrypt-certificates there.
; This merely retains r/w access rights, it does not add any new. Must still be writable on the host!
ReadWriteDirectories=/etc/ssl/caddy/v2
; They further restrict privileges that can be gained by caddy. Uncomment if you like.
;CapabilityBoundingSet=CAP_NET_BIND_SERVICE
;NoNewPrivileges=true
# Global Options
# https://caddyserver.com/docs/caddyfile/options
admin off
grace_period 10m
#Order for rate limiting
order rate_limit before basicauth
# TLS Options
email ssl@example.com
on_demand_tls {
ask https://sites.example.com/allowed
#Set Certificate Location
storage file_system /etc/ssl/caddy/v2
:443 {
#ca https://acme-staging-v02.api.letsencrypt.org/directory
on_demand
#Set GeoBlocking
@geofilter {
maxmind_geolocation {
db_path /etc/caddy/GeoLite2-Country.mmdb
deny_countries RU RO VN
reverse_proxy @geofilter http://127.0.0.1:7777
#Set Rate Limiting
rate_limit {
zone dynamic {
key {remote_host}
events 60
window 120s
#CDN Setting
uri replace s3.amazonaws.com/example static.example.com
#Set Headers
#Enable Compression
encode {
#gzip 9
#Define Logs
roll_size 25
roll_keep 10
roll_keep_for 7d
format filter {
wrap console {
time_format rfc3339
time_key timestamp
fields {
request>headers>Accept delete
#Define Snippet for On-Demand TLS
(onDemand) {
on_demand
#Include Redirs
import redir2/*
import redir2MultiDomain/*
All issued certs are from ZeroSSL, We have tried forcing a cert renewal by deleting old cert and OCSP files. While doing the reissue process, these errors were noticed in the logs
Sep 1 08:37:45 ip-172-31-6-120 caddy[42779]: {"level":"error","ts":1662021465.443806,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"www.example.com","issuer":"acme-v02.api.letsencrypt.org-directory","error":"HTTP 400 urn:ietf:params:acme:error:malformed - JWS verification error"}
# ll /etc/ssl/caddy/v2/certificates/
total 60
drwx------ 3 caddy caddy 6144 Apr 24 08:01 ./
drwxr-xr-x 6 caddy caddy 6144 Sep 12 11:04 ../
drwx------ 1072 caddy caddy 55296 Sep 12 09:14 acme.zerossl.com-v2-dv90/
Forcing a renewal is the only thing we’ve tried this far
