1. My Caddy version (caddy version
v2.0.0-beta.20 h1:oUNG1uh0UV8LWLlAVDZolFzk112++V/pxY+fF0HLmlY=
I use docker-compose with the latest docker from the Docker CE repository on Debian 10.
version: '3.7'
image: caddy/caddy:latest
dockernet:
ipv4_address: 10.0.0.2
ipv6_address: fd00::2
- ./caddy/data:/data
dockernet:
external: true
admin off
(proxy) {
example.net, www.example.net {
reverse_proxy nginx_acb_nginx:8000
reverse_proxy /_matrix synapse:8008 {
import proxy
example.net:8448 {
reverse_proxy synapse:8008 {
import proxy
example.org, www.example.org {
reverse_proxy nginx_acb_nginx:8001 {
import proxy
forum.example.org {
reverse_proxy forum:4567 forum:4568 {
import proxy
I’m trying to enable the loadbalancing policy “ip_hash” which is found in the docs here.
{"level":"info","ts":1586120838.0300763,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
run: adapting config using caddyfile: parsing caddyfile tokens for 'reverse_proxy': /etc/caddy/Caddyfile:32 - Error during parsing: load balancing policy module 'http.reverse_proxy.selection_policies.ip_hash' is not a Caddyfile unmarshaler
{"level":"info","ts":1586120839.3675978,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
