Hi,
This is more of an announcement
It has been established that by downloading a version of Caddy where both the dns
server type and grpc
plugin is chosen causes a panic
panic: http: multiple registrations for /debug/requests
An issue has been logged inside the caddy-grpc project.
The reason is because both dns
and grpc
use the Go gRPC package
which imports “golang.org/x/net/trace” in it’s trace.go file which in turn import the "golang.org/x/net/trace"
package. The trace
package has an init function that registers routes for the default http mux. This is where the panic occurs.
I will need to figure out if there’s a way (or even possible) to change this behaviour from within my plugin. For now a short term solution would be disable either plugin if you want to use the other one. (Obviously not ideal for long term or in instances where both plugins need to be used)
Pieter
