iocage jail in freebsd 12.2-RELEASE-p2
caddy run -adapter caddyfile -config /usr/local/www/caddy
not setup as a system service (yet)
order jwt first
(encoding) {
encode gzip zstd
(dns) {
dns cloudflare xxx
(primary-auth) {
jwt {
primary yes
auth_url https://auth.xxx.xxx/oauth2/google
trusted_tokens {
static_secret {
token_name access_token
token_secret xxx
allow roles superuser
(auth) {
jwt {
trusted_tokens {
static_secret {
token_secret xxx
auth.xxx.xxx {
import dns
import encoding
route {
auth_portal {
path /
cookie_domain xxx.xxx
backends {
google_oauth2_backend {
method oauth2
realm google
provider google
client_id xxx
client_secret xxx
scopes email openid
user "@xxx.xxx$" regex add role superuser
jwt {
token_secret xxx
ui {
links {
"Plex" https://plex.xxx.xxx
route /version* {
respond * "1.0.0" 200
route {
redir https://{hostport} 302
plex.xxx.xxx {
import auth
import dns
import encoding
reverse_proxy http://plex.xxx:32400
proxy.xxx.xxx {
import primary-auth
import dns
import encoding
root * <path>
I was previously using the jwt and auth plugins for Caddy v1 and they eventually worked really well, when I got the configuration right in the end. Now I’m trying to switch to Caddy v2.
One of the things I got through the authorization framework in v1 was an URL to the user’s profile picture as part of the jwt. Now when using jwt and auth portal, I’m not getting that information. Is there a configuration part somewhere I’ve missed to get this information through?
I’m also interested to know if there’re any major issues with the configuration I’m using. I’m completely new to Caddy v2 but used v1 a bit.
No real output as much as missing information in the jwt.
I’ve tried looking the github pages for jwt and auth portal to get a better understanding about the claims and such, but I’m not getting much wiser. Since this isn’t really my forte, I’m probably not even using the correct vocabulary. I’m hopefully making myself understood, anyway.
