JSON config for reverse proxying to a path/subdirectory
2.4
Caddy API as a systemd service
Ubuntu 20.04
service caddy-api start
N/A
   "admin": {
      "disabled": false,
      "listen": "localhost:2019"
   "apps": {
      "http": {
         "servers": {
            "srv0": {
               "listen": [
                  ":80",
                  ":443"
               "routes": [
                     "handle": [
                           "encodings": {
                              "gzip": {}
                           "handler": "encode"
                           "handler": "reverse_proxy",
                           "headers": {
                              "request": {
                                 "set": {
                                    "Host": [
                                       "somedomain.com"
                                    "X-Forwarded-Proto": [
                                       "https"
                                    "apx-incoming-host": [
                                       "somedomain.com"
                              "response": {
                                 "set": {
                                    "apx-hit": [
                                       "true"
                           "transport": {
                              "protocol": "http",
                              "tls": {}
                           "upstreams": [
                                 "dial": "targetdomain.com:443"
                     "match": [
                           "host": [
                              "somedomain.com"
                     "terminal": true,
                     "@id": "vhost_1012"
      "tls": {
         "automation": {
            "on_demand": {
               "ask": "https://mydomain.com/check-domain"
   "logging": {
      "logs": {
         "default": {
            "level": "DEBUG"
I’m wondering if there’s a way to reverse proxy somedomain.com to targetdomain.com/some-subdirectory in a way that would append any additional paths to the end like this somedomain.com/another-path reverse proxies to targetdomain.com/some-subdirectory/another-path.
To the user, it should just look like they’ve gone to somedomain.com but they get the same results as if they went to targetdomain.com/some-subdirectory.
No error log on this one
Searching the docs, but I haven’t found anything really related to this specifically. They’re also taking 1+ minutes to load a page which has made the search slow enough that I decided to ask on here instead.
N/A
Yes, use the rewrite handler before reverse_proxy, and using a target "uri" of /subdir{http.request.uri}.
Docs for the rewrite handler (yes, sorry that it takes so long to load :frowning_face:):
In general, I recommend trying to do what you want with the Caddyfile first, then running caddy adapt --pretty to see how the JSON looks.
Thank you Francis! Much appreciated.
