caddy run --environ --config /etc/caddy/sently.json
Distributor ID: Ubuntu
Description: Ubuntu 20.04.2 LTS
Release: 20.04
Codename: focal
Paste command here.
Paste config here, replacing this text.
LEAVE DOMAIN NAMES INTACT.
"apps": {
"http": {
"servers": {
"myserver": {
"listen": [
":443"
"logs": {},
"routes": [
"handle": [
"handler": "reverse_proxy",
"upstreams": [
"dial": "localhost:8001"
"tls": {
"automation": {
"on_demand": {
"ask": "http://localhost:8001/proxyCheck"
"policies": [
"issuers": [
"api_key": "...",
"email": "",
"module": "zerossl"
"on_demand": true
"logging": {
"logs": {
"default": {
"writer": {
"filename": "/var/log/caddy/caddy.log",
"output": "file"
Because of this issue Questions about Renewing before TLS-ALPN-01 Revocations - Help - Let’s Encrypt Community Support we lost a lot of certificates. For a few days, we still got some certificates in the queue, and for some of our users, it is critical.
It is possible to manipulate caddy SSL certificates queue to order some priority or maybe generate certificates manually? Or maybe speed up it somehow
https://drive.google.com/file/d/1610XjhO_B-vNwT44BHNoevGsH4UnWKWr/view?usp=sharing
